- Joined
- Oct 18, 2023
- Messages
- 189
Today I discovered one of the tabs on the battery cover of my SDS100 had broken loose. I was able to superglue it back, but I ordered a spare cover.
Neither of my 2 batteries looked bulged. One of them the cover closes quite easily. The other the cover closes without much effort, but seems a slight bit tighter. I had not really noticed before the difference in ease of battery cover closure.
I used a digital caliper and measured the thickness of each in the middle. One is 28.6mm thick and the other is 29.7mm thick. I assume the thicker one put extra pressure on the already inferior tab.
Has anyone else measured these batteries to see what the usual thickness is? Is 1.1mm extra thickness the issue, or did the battery cover just not hold up because it is not very sturdy to begin with. Both batteries are charging and working fine. I already had to replace the battery cover latch when it was only a year old. The 3D printed latch is much more sturdy.
If they bulge, wouldn't it have been better if Uniden had encased the cells to allow some minor bulge instead of a tight clearance of the cells within the case of the battery itself?
For the price of these radios you would expect a more durable case. The case of my not very expensive 2 meter/ 70cm handhelds are as robust as a Motorola brick. Dropping them never results in cracks, just scuffs or dents. I have not dropped my SDS100 yet, but it does not evoke much confidence of survival without case cracks or battery cover damage.
