- Joined
- Jan 2, 2003
- Messages
- 149
- Reaction score
- 8
Few things first... :roll:
I just got a new digital camera (Fuji Finepix) and I'm still trying to find it's sweet spot for autofocusing. I'm not that impressed with the near-field pictures it takes, but I'm sure you can get the gist of things.
Second, everything you are about to see can probably be had from around your house.
For the "housing", I used the plastic packaging that comes from 70% of the pegged products at WalMart. For instance, I used the packaging from my fairly new USB hub.
I currently have scotch tape holding the (1) seam together. Normally, I would look down upon this, but given the space constraints, it's the only thing that would get the job done adequately. As mentioned, there is only (1) seam and everything else is bends and folds.
The "contacts" are executed by trimming the foil trays that take-out food comes in. Check your pantry, you've probably got some! I also went the extra length to go to Home Depot and buy a pack of 1/4" springs. They can be found in the door/window aisle. A pack of 4 springs is ~$2.00... although you'll only need 1 spring, cut 4 times. These are used for applying proper tension to the batteries to engage the contacts.
Okayyyyy, here we go...
The main contact board where the direct output of the batteries come from. Notice springs and foil. The leads were not connected at the time but were later attached to the left and right.
Outside of radio: Looking in.
Outside of radio: Unloaded, with (4) Energizer 2500mAh NiMH cells.
Outside of radio: Loaded.
Installed in compartment: Nice and snug.
Any questions/comments are strongly suggested through this thread, but feel free to contact me via email.
- Joe
- Joe
