BC370CRS Hum Question
pgde
Tucson, AZ
Hi all:
Newbie here. I have the referenced scanner. I thought it would be good to hook the scanner's headphone output to my PC sound card input so I can hear the output over my PC speakers. I used a regular audio patch cord. While I can hear the output, for some reason, I get a low frequency hum over the speakers that isn't there when I listen to the scanner by itself. Any idea why I cam getting this hum? Is there some kind of filter, etc I can get to eliminate it?
Thanks so much for your help!!
P.
pgde
Tucson, AZ
Just installed the Ground Loop Isolator and it worked great and solved my problem.
Thanks so much for the help from a newbie!!!
P.
pgde
Tucson, AZ
Hi All:
Mid-January update.
The ground loop isolator I bought at Radio Shack seems to be working fine. However, I have noticed that a hiss will begin to build up between scanner receptions. Once a transmission has been received, the hiss is gone but begins to build up between transmissions. It is somewhat noticeable. Any ideas what this is and whether I can fix it somehow?
Thanks so much!
P.
