BC785D - fix for intermod?
WD4CQ
New Bern, NC
I have owned (2) Bearcat BC785D Radio Scanners for over 6 months now that I really enjoy, However I get lots of intermod. I am using the scanner as a base with an outside discone antenna.
Question? Does anyone have any experience or success using these filters
below on the BC785D scanner and if so, which one? If I had a handfull of filters in my possesion, FM band, Business/Paging band and different brands, I could try them out and simply know which ones worked and which band to filter out. I do have a powerful FM station in the area on the low end of the FM band, also a powerful NOOA station on 162.4 Mhz and the common 152 (somewhere) Mhz paging freqs in my area. I love the BC785D but the intermod is driving me nutz! Any experience from anyone with a BC785D?
Filters for Radio Scanners:
http://www.radiofilters.com/
http://www.stridsberg.com/prod02.htm
http://www.grove-ent.com/filters.html
N7OLQ
Scanning since '77
Utah
I noticed the the 785 is slightly more prone to intermod than the 780.
I have heard good things about the PAR filters, but I have not used one. My problems come from 926MHz pagers. I have used the Stridsberg FLT800 with pretty good success.
I found that lowering my antenna from the peak of my roof to a lower area over the garage helped even more than a filter.
A directional antenna can also help if the problem transmitter is not in the same direction as the target transmitter.
Good luck, and don't forget you can always MOVE.
