Bc785D, ignoring Pl tones???
Brentd2183
New York
I have 155.16 which is lifeflight for worcester mass, on pl 118.8 there is a trinity dispatch i get talk on too, they are 94.8 for a pl. I programmed the scanner for the 118.8 but it still recieves trinity? what gives?
Brent
flyingwolf
Old School
Northern Kentucky
If you want it to only respond on the pl code you want you will need to close the bank.
I know on the pr series of scanners it works that way. Small amount of experiance with the BC and in most cases it is the same way. Hit that owners manual to see how to run a bank in closed mode.
rdale
Lansing, MI
Ignore the above post, there is no such thing as a closed bank in the Uniden lines and in any case that would be about trunked systems...
loumaag
Silent Key - Aug 2014
Katy, TX
This is true.
rdale (continued) said:
...in any case that would be about trunked systems...
This is not accurate. "CLOSED" bank operation on GRE scanners, which have CTCSS or DCS capability, will keep you from hearing transmission without the proper tone/code while scanning. The Pro-96 will also do so while sitting on a frequency in CT or DC mode.
K5MAR
Stillwater, OK
On my 780, which I expect is similiar to the 785, you set the Squelch Mode in the menu. There are three different modes, Carrier SQ (default), Tone SQ, and Tone Search. Tone SQ mode: "The scanner will stop on any active frequency for which either no sub-audible tone has been programmed or for which the user-programmed sub-audible tone is also active."
I don't use Tone Search, as it is so-o-o-o slow.
Mark S.
RolnCode3
Sacramento/Bay Area, CA
Mark S.
This is exactly correct.
Go to Menu -> 3:System Option -> 8: SW Mode -> Tone SQ.
This will set the scanner to only open squelch on the tone.
flyingwolf
Old School
Northern Kentucky
As I said not much experiance with the Uniden lines.
Just giving him an area to start looking. Put nice to know now.
