BC796D ssd file question
seamusg
Grand Blanc, MI
Can anyone tell me what column 1 and 2 are used for in the TRUNK section of the ssd file? Column 3 id TG number and 4 is alpha tag.
thanks
Jim
seamusg
Grand Blanc, MI
My question is about the SSD file it self. NOT the program screen.
This is what I'm asking about:
TRUNK,1,100
0,,000016,"Wrrn PD Motor"
the 1st column is the 0
the third is the talk group
the forth is the talk group alpha
The Bank section is described, but not the Trunk section
Frequency,Description,Trunk,Att,Delay,Beep,Record,Mode,Steps,Tones,L_O,PRI
BANK,1,100
851.48750,"Warren - NC",On,,,,,NFM,12.5K,,,0
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
column 1 is for type trunking system. Mine are as follows
0=Mot 800 in banks 1, 3, 4, 5, 6, 7 & 10.
5=EDACS regular in bank 2
3=Mot 400 in bank 8 & 9
Other type systems would use the other numbers is my guess. I could load a Mot 900 and an LTR standard and find two more numbers, but its too much trouble to go from a mem file to the scanner then back to this crappy ssd file.
Mine also has the number 1 in column 2 prior to the first ID of bank bank 1 only. Bet that is a priority flag.
fmon
Eclipse, Virginia
2=Mot 900
8=LTR
Edit: I conned myself into adding the Mot 900 and LTR above. :roll:
seamusg
Grand Blanc, MI
Thanks for the info.
What I cant figure out is the 2nd column. I get groups of numbers on various banks and can't relate them to anything.
Jim
