trixwagen
Other than saving a few bucks, is there any reason to purchase a BC898T over a BCT15?
I'll be mostly listening to milair, if that makes any difference.
GreatLakes said:Probably the biggest difference is the BC898T has larger controls, and a manual tuning knob, the BCT15 does not. The BCT15 has alpha-numerical display, the BC898T does not.
trixwagen said:Alright, since I'm in the $200 range, BCT15 or BC780XLT? Is the answer that obvious again?
warrior420 said:Do it, Do it, Do it.
you wont regret it.
I also use my BC780 to listen to mil air and asked myself the same question - upgrade to a BCT15? I have a BR330 which is almost the same radio, so I know how the BCT15 would work.trixwagen said:Alright, since I'm in the $200 range, BCT15 or BC780XLT? Is the answer that obvious again?
eorange said:I may want to jump directly to 260.9/NORAD. I know the # of this freq because I see it so much. This is easy to do on the BC780, and impossible to do on the BCT15/BR330.
eorange said:By the way, almost none of these posts compared the BCT-15 to the BCT-8/BC780 with regard to its MIL AIR capability.
Can you elaborate on the mil air performance?madnachos said:I monitor a lot of MilAir with my BCT15...works very well for that. I had a BC780 for a short time and IMO the BCT15 is a superior unit across the board.
Not sure what you want to hear...its the best milair scanner I have. It outperforms my Pro97 and 96 for my use. Never really done any testing its just the scanner I snag more milair transmissions with.eorange said:Can you elaborate on the mil air performance?
