BC898T opinions?
FrankJ
Euclid, Ohio
I'm considering buying a BC898T to replace a 780XLT. I don't really need the alpha tags, so that's not a problem. I really like the top mounted speaker and tuning knob on the 898T. Performance wise, how do these 2 scanners compare (especially on the milair bands)?
Frank
iMONITOR
Silent Key
S.E. Michigan
I think you'll be satisfied with the BC898T. Be sure to buy a new one as some of the first generation ones had minor issues. You shouldn't have to pay more than $200.00 for a new one. I know you're into Mil-Air, and the BC898T performs very well on that band.
Consider getting ScanControl software for the BC898T. It works very well and will give you the alpha/numerical tags on your computer (if you want them), and adds other features such as logging, and recording.
You can download a free demo at:
ScanControl
http://scannersoft.com/
If you get one print out page 46 & 47 of the BCT-8 so you will know which of the 4 plans to use when you set the radio to CC only. Plus it will give you info on the EOT setting. There are 8 options you can get to with the VFO knob. #4 is ON/OFF but have no idea what it is for, but if I turn it OFF it will not trunk. Hope this helps.
FrankJ
Euclid, Ohio
Thanks. I used to have an 895XLT years ago and that was REAL HOT on the VHF Low Band. I couldn't believe it! Hopefully, Uniden used the same design on the 898T. I ended up selling the 895XLT since it wouldn't "switch AM/FM modes". As you mentioned, I'm a big milair listener!
Frank
Dubbin
Findlay Ohio
Frank before you jump on the 898 you may want to consider the BCT15.
N1SQB
Somewhere On Earth
Hey Frank!
I own the 898T. I love it. I too like to tinker in the mil-air areas. You WILL NOT be disappointed there. The BCT-15 is also a great performer but if you are coming from a 780,then an 898T will be plug and play as far as use is concerned. The BC-15,while a great radio, will take you some time to get used to if you are used to a 780. I would definitely recomend the 898T for the simplicity of use especialy if you are monitoring mil-air. Either radio is a good choice,but I think the 898T will suit your needs better.
Manny
bwhite
Carroll County, MD
As eluded by another poster, the manual leave much to be desired.
Some of the buttons are multi-function and not very logical.
