BC898T TV CH 8 Problem
N9WP
Lebanon, IN
Thought I'd ask you guys about this. I've been a scanner listener for years and purchased the new BC898T this past weekend. I have 5 other scanners in the house (BC895XLT, BC245XLT, BC860XLT, BC210XLT, and a BC100XLT). This problem I am having does not exist on any of these other scanners.
The problem: The BC898T does a great job of trunking the Indianapolis MECA systems and Hamilton co EDACS system. My problem is with conventional frequencies. My local county uses simplex, a base to car frequency of 155.130 and the car to base freq of 154.890. On 154.840 I have a solid signal of the TV channel 8 video that bleeds over to my counties simplex frequencies along with other frequencies in that same area. I can clearly hear the audio from TV Channel 8 around 156.000 wiping those area freqs out too. I am located 15 to 20 miles away from the TV Channel 8 transmitter. I put the scanner in my truck to see if it was just localized and drove at least 5 miles in the opposite direction of the TV Channel 8 tower and the signal didn't change much. It is full scale on the S-meter and only dips a little bit when driving around buildings. None of my other scanners or ham gear have this problem. Is there a problem with my scanner? I do not want to purchase a filter, I'm looking at returning the scanner for another one if you guys think it's just this 1 scanner. It does this while connected to the stock antenna, the mobile antenna, and 2 scanner antenna's I have in the attic. If I disconnect all antenna's I don't receive it but I also can't receive anything else.
In the 2 meter ham band, I can pick out TV Channel 13's audio too...Isn't this suppost to be a tripple conversion scanner? The sensitivity is a tad better then my BC895XLT. If I open up the squelch on the BC895XLT I can't hear any of this stuff. On the BC898T, I can close the squelch all the way and it still bleeds through. Using the ATT just drops it a couple bars on the S-meter and makes it completely deaf listening to anything else.
Like I said, I just bought it Saturday so I could exchange it for another BC898T. Ideas? Suggestions? Is there something I could change? What's it doing???? Do you think I included enough details?? HAHA
Brian, N9WP
i am wondering if you have a cable leak in the area. did you try moving the radio out to the car and take it for a ride away fromyour house?
try listening to 145.25- its the video for cable channel 18 for most (not all) cable systems.
hope this helps bill simpson
jim202
New Orleans region
If the other scanners are not hearing the same problem, I would point the finger at the new scanner. If you did have a cble leak, all the scanners would be doing the same thing. Also the cable leakage would be only in a small coverage area of a couple hundred feet. Normally comes from a loose or corroded connection.
Take the scanner back and get something else.
Jim
Voyager
Jim
It's also on the wrong frequency. As mentioned, CH 18 is 145.250 video carrier. CH 8 would be 180-186 MHz and CH 13 is 210-216 MHz.
CHs 18-20 would cover 144 - 162 MHz. If it's a cable leak, you would hear those channels, not CH 8 or 13.
Joe M.
N9WP
Lebanon, IN
Thanks for the help guys. I'm out in the country and probably 2+ miles from any cable lines. I drove around in the car several miles away from Indy where CH 8 is and still heard the problem. I have a friend that also purchased the same scanner and he has the same problem. I ended up sending it back and getting the 796. The 796 has the TV CH 8 video signal on 154.8 but it doesn't bleed off of that frequency so all is good. The 796 is a sweet radio. Like I said, I have the BC895XLT and there are no images of TV channels anywhere in the 150 - 160 mhz range. So my opinion is the BC898T is not an upgrade if you live within 40 miles of a TV CH 8 transmitter.
