BCD3252P2 group select
greenwoodboy
Greenwood, AR
Hello All, On a Uniden BCD3252P2, I have a multi-site P25 system programmed. It all runs well. I have assigned quick keys to each site. However, I cannot determine how to select one site and turn off the others. I don't need or want all sites running simultaneously. Can anyone tell me how to select one site only?
tvengr
Well Known Member
Baltimore County, MD
Here is a PDF file which will answer all of your questions about using quick keys:
  • Uniden Scanner Quick Key Instructions DMA.pdf
ProScan
Software Provider
Ontario, Calif.
Thanks for the info. I have not been able to turn on/off sites in the trunked system still. I will continue to look at it though.
I think you want to turn off and on groups and not sites. If so, see the Group Quick Keys section. The software you're using needs the groups assigned GQKs.
greenwoodboy
Greenwood, AR
The "sites" in this trunked systems all have quick keys assigned. These are not groups.
tvengr
Well Known Member
The sites are each assigned a different system quick key number. You then toggle sites on and off by pressing the system quick key number on the scanner keypad. On the SDS100 and BCD436HP it is different. Departments and sites share the same set of quick keys on each system. On the BCD325P2, you are dealing only with system and group quick keys. There are no favorites list quick keys. Read the PDF file again carefully. It should clear up any misunderstanding.
