Just wondering if this radio can be programmed manually similarly to the 125? Not looking to add any trunking stuff to it at this point.
I agree! You will wear out the scroll knob on your radio selecting characters for alpha tags. It is so much faster and easier typing them in directly from your computer keyboard. Also, there is far less of a chance of programming errors. You will be able to view everything at a glance rather than being buried in scanner menus. For your scanner, you can use FreeSCAN if not using DMR or NXDN and it is FREE! For DMR or NXDN. you will need ARC XT or ProScan. Both have a free trial period to decide which one you like better. I use Butel ARC XT Basic to program my BCD325P2 and BCD996P2. The Pro version adds virtual control and logging.Alpha tags make programming software worth it even on conventional channels.
Gymbag- The Uniden Bearcat BC-325P2 is a great handheld scanner providing you get rid of the stock antenna and purchase a Diamond RH-77CA or a Remtronix depending upon what band you want to monitor.Just wondering if this radio can be programmed manually similarly to the 125? Not looking to add any trunking stuff to it at this point.
