dkishton1486
- Joined
- Dec 3, 2013
- Messages
- 8
- Reaction score
- 2
What would be the best antenna for the BCD325P2 for long range? Looking to possibly getting some channels for some areas around 40-45miles. Not sure if its even possible.
Diamond RH-77CA 25-1,200Mhz 15" rubber antenna-the BEST all band PERIOD!!!! Look for this item on Amazon.com or contact me as I had the analog version of this scanner-BC-125AT.What would be the best antenna for the BCD325P2 for long range? Looking to possibly getting some channels for some areas around 40-45miles. Not sure if its even possible.
I wouldn't go as far as saying it isn't going to happen. This really depends on the power output of the repeater, terrain, environmental RF, closer stations TXing on the same frequency and a few other factors. When conditions are favorable, it may not be the clearest, most reliable signal if you're monitoring from the ground with a handheld. As others above me have mentioned, the best option for distance monitoring would be to get an antenna high above your roof line. Telescopic antennas are a nice improvement too, I've had good results with my Comet BNC-W100RX and Diamond RH789trying to recieve signals 40 to 45 miles away is not going to happen on a hand held with a rubber duckie or any other antenna as your walking around unless your in the desert maybe..
Frowned upon why? Potential stress on the BNC connection?
That's exactly what I do, I never had an issue
I particularly like the "elbow joints" I guess you'd call them. Makes for easier collapsing if you want to put the radio in your pocket
