BCD396xt programming conventional and trunked
08GMC4X4
Wirelessly posted (BlackBerry9000/4.6.0.304 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
Does anyone know if I can make a new system that will scan conventional and trunked at the same time. For instance if I wanted to program only Madison NJ (07940) PD, Fire, EMS and also Morris County Trunked MIRS. Instead of storing them as two seperate systems. When I go to program a new system it will only allow me to pick one system ie. Mot conv edcs
You have program it as two separate System and then assign the same System Key # and then you can assign one group # conventional and an other to the Trunk.
This way you can bring it up at the same Time and enable either one or both.
08GMC4X4
How do I set up system key and group keys. I'm still new to this scanner
