BCD436 Case
greggk
York,PA
Hi all. First, I am obligated to say that this is probably the wrong place to post this question.
With that out of the way, I have a question about the case for the BCD 436.
When I got mine from scanner master, I noticed that no cut out was there to monitor the flashing LED. (The one that should have been on top of the radio but is at the bottom) Scanner master promptly repaired mine by placing a small, punched hole where the LED should be.
Unfortunately, unless the scanner is in the case exactly, you cannot see the light. Even if it is in the right place, the small hole makes it hard to see.
Has anyone modified their case? Thats what this post is all about.. a long story for a simple question. I appreciate any help. Thanks. Greg
