BCD436HP gps port broken
gstrugs
I noticed the other day that my BCD436HP mounted in my car lost the gps signal. When I tried to check the plug, a small piece of plastic came out with the plug. Pins aren't broken or bent but no signal from gps puck. Looks like I need to send it in for repair unless someone here has any other ideas.
Sent from my SM-G950U using Tapatalk
JamesO
McLean, VA
Not an unusual problem. I have a HP1 which had broken plastic in the GPS port when I received it. It worked fine with the Uniden GPS puck but the connection was loose. I purchased a rechargeable GPS module from a member and due to the way the unit detects the scanner, I had some issues and had to tension the cable in a specific manner to get the GPS to turn on, not a problem with the GPS, just a problem with the connector.
I purchased a replacement connector and swapped it out myself, but because it is like surface mount soldering you need to have skills and decent equipment. If you think your solder skills are up to it, you can order a replacement connector like the one in the link below:
https://www.ebay.com/itm/3-Hirose-E...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Or consider sending your scanner to jonwienke here in the forum for either repair and/or installation of an internal GPS module which is no more expensive than sending the scanner to Uniden for repair.
I see he just posted above me while I was looking for the GPS connector info.
Bronty
Amherst, NY
My 2 scanners arrived at Jon’s house today (SDS100 and 436) and I’m getting a rechargeable and cable for my HP-2.
Pictures and reputation precedes him.
Sent from my iPhone using Tapatalk Pro
JamesO
McLean, VA
See links in Post #2 above.
The price is typically no more than Unidens fixed repair cost with shipping as I recall.
I think he does the conversions just for beer money!
