BCD436HP help
oscarb
Sun City West, Az
We bought a Uniden BCD436HP downloaded sentinel software and install Maricopa Co p25 to radio. Just Wanted Sun City West Posse, 3201 with white tanks. Got rid of everything else we think. We get 1 or 2 part transmissions then nothing after that all day. So something we've done is not right.
We have never owned a scanner so... we are really new to this.. any help would be Great.. We did figure out how to save and load files. I could post if needed.
oscarb
Sun City West, Az
Thanks for the response, I am looking for sun city WEST talk groups under Maricopa Co, Maricopa County (P25) systems, Project 25 Phase II
scrolling down it says "
3201 c81 TSCW PosseSun City West Sheriffs Posse Emergency Ops
and white tanks is the other part, I do receive it at times like right after I turn it on but after a while it stops.
oscarb
Sun City West, Az
Thanks again, yes Emergency Ops was turned on when brought in with sentinel, tried everything that we could find on internet. Just put SCW Posse 3201 in by it self and white tanks. worked for 2 to 3 minutes and then broken calls then nothing.. Think we got a bad unit.. Or its way over our heads.. Might just return it..
oscarb
Sun City West, Az
FYI Found out I Had it programed correctly, If I hold it up in the air or outside it picks up great. White tanks repeater is 16 miles away, I thought this radio would pick up better. Maybe a better antenna.. any suggestions??
Thanks for all the help...
cfsimmont
Arizona
If you are using the stock antenna, then yes there are better antennas. Remtronix works well on the 700/800mhz bands, and they will only cost you about $30 I think. Scanner Master and a few other sites should have them in stock.
n0doz
Metro PHX AZ
May I suggest one of those small magnetic base antennas with the thin whip? They're the ones with the base that looks like a "Hershey Kiss" and usually have 10 to 15 feet of small coax with an SMA connector. I have 3 of them and putting one on the mantle or or top of tall furniture works great with my 436. They're really cheap on Amazon.... here's an example: Bingfu 136-174, 400-470 MHz Antenna $9.99, works well for 108-137 aircraft and 700-900 MHz receive as well.
6079smithw
Near the Biggest Little City
You're going to want to have some sort of metal ground plane under the mag for best results, the bigger the better... kitchen
appliances are great for that; refrigerators the best for height and mass. (Strongly suggest securing spouse/SO permission prior
to doing so if applicable... speaking from experience...:))
n0doz
Metro PHX AZ
You are correct! I forgot to add that, thank you. But for a quick non-transmitting setup, I've used a minimum of metal. For instance, my mantle setup right now is a 19" "Hershey Kiss" mag mount on one of those metal electric junction box covers. For DPS, I'm receiving all the local districts including Metro West, which I usually have quite a bit of difficulty with.
I'd like to mention another external antenna idea for anyone not familiar with them that's working great for me: a small dipole I made from two of those Signal Stick antennas built and sold by a Ham club up in Utah. I used a 2" L-bracket, an SMA-F connector, and a 10-foot RG-174 coax with an SMA-M on one end and an SMA-F bulkhead connector on the other. The antennas, both with SMA-M connectors, are the dual-band whip model that they sell for about $20 each. I drilled out the two holes in the L, both on the same side. The SMA connector goes thru one facing "down" while the bulkhead SMA goes in the other facing "up" or the opposite direction. I soldered the center conductor of the plain SMA to the body, shorting it. I then used the included nuts to secure both connectors to the bracket, Finally, I screwed on the 2 antennas. The one on the bulkhead becomes the radiator and the other is the reflector. Works extremely well as a quick portable antenna that can be set up virtually anywhere and does not require a ground to use. I set it up in the bedroom, high up on the wall and connected to a radio on the headboard. We have dark paint on the walls, so the antenna pretty much disappears, so the Mrs. isn't offended. Hope this helps someone.
6079smithw
I'd like to mention another external antenna idea for anyone not familiar with them that's working great for me: a small dipole I made from two of those Signal Stick antennas built and sold by a Ham club up in Utah. <<>>
I know I have a couple of those in a drawer somewhere, that sounds like it's worth building... Thx for the info!
