BCD436HP Priority scan
jdolina
Lorain Ohio
I might be missing something but I have priority scan set in the profile and have multiple startup keys. If I start using one setup for trunk only systems I will get the message no priority and when I start it scanning priority is automatically turned off. If I then use another startup key with conventional systems and priority, priority scanning is off and I must go in the menu to turn it on. I would think the profile setting should be reloaded on each startup?
safetyobc
South Arkansas
Because the priority scan is for conventional only. If you have priority TGID, it will automatically check that while on the trunk system.
jdolina
Lorain Ohio
I understand that and I do have a priority for a TGID in one of the trunk systems. I understand why priority is turned off when starting with that startup key. I do not understand why it is not turned back on automatically when I start with the convention startup key.
