GermanSloth
- Joined
- Sep 19, 2021
- Messages
- 1
Hi all, I have a BCD436HP and an SDS100, both mirrored with the same channels/favorites list. The favorites lists that I scan are composed of a mix of about 35-50 channels in total programmed. Some conventional, some P25 trunked, and some simulcast frequencies in there. Some favorites lists have all types mixed into one list. I don't normally scan a majority of them at once. Usually 2-4 Lists with a total of 10-15 channels. Often both scanners will cut off the beginning of a transmission. I’ll hear a response, but not much of the initial transmission. I will hear transmissions normally when a response is given quickly, the scan delay is set to 2 seconds post transmission. But the initial is cut off a bunch. I have set the conventional frequency delay from 400ms to 0ms. Squelch is set to 2. This delay happens regardless of frequency type, conventional, or trunking. Sometimes I’ll know there was a transmission, and they will sporadically pick them up, if at all. I’m trying to figure out what is causing it and how to remedy it. Any tips, advice, or solutions is greatly appreciated. I’m new to trunking scanners, and the Sentinel software.
