andy404ns
My SDS100 has been having an issue where sometimes a transmission won't open the squelch. This occurs both in scan mode and hold mode. I originally thought it was limited to P25 One Frequency systems (and as those are known to be problematic I was mostly ignoring it) but I'm now seeing it on conventional channels. Most of what I listen to is P25 so I'm not entirely sure if it's limited to digital only.
I'm not 100% sure but it seems like it has been happening more frequently over time.
For troubleshooting, I have the SDS100 next to my BCD396XT and my BCD996T. All three are running off the same antenna that is split on a Stridsberg multicoupler. I confirmed that there are times where both of the BCDs will open squelch and receive transmissions while the SDS does not. Since the problem only happens occasionally, I know for sure that the programming is fine.
Has anyone experienced this type of issue before? I searched around the forums but most posts are "not receiving at all" type things. I wonder if there are any digital settings or filters that might be causing a problem?
Thanks in advance!
Andy
Thanks in advance!
Andy
