wa2sqq
I set my 536 to discover the PL tone being used on a conventional channel. I’m trying to figure out how to set the display (2 line / 3 line) to display the tone used and / or discovered.
Thanks in advance
Thanks in advance
Done that, but no tone shows up, on any channelPress Func then 9(DISP) to toggle 3 Line Display Mode
I have it on, let me try that thanks3 line display needs to be off
3 Line Display Off
You know John I retired my x36s a while ago, so I just can't look.. now I'm remembering three line display was like a simple display as opposed to a detailed display.
I'm also on latest FW as of this post (1.28.24)I have done this before, but since the last firmware update, it does not respond the same.
Very interesting at least I know I’m not going crazy. I’m going to try making the change using the Sentinel software.Interestingly it doesn't work for me either. Every other F+x feature seems to work just fine (ATT, IFX, Weather, SRCH). Weird. Is it dependent on some other setting? I am going through ProScan by the way, haven't tried it locally yet.
I can't comment about you going or not going crazy.Very interesting at least I know I’m not going crazy. I’m going to try making the change using the Sentinel software.
Correct, double click the knob, "F" shows in the upper left corner, press "9" and I get the error boop.Difference with Proscan is you need to double click the knob for Function.
How old is your scanner. I have four 536's. One is in the 3800 series and the other 3 are in the 4800 series. All have had the clock battery and the dim display LED repair. The one in the 3800 series also had the distorted headphone audio repair. All four have the 1.28.24 firmware and I have no problem switching the display on any of them. A hardware change could possibly be causing the problem. I do not use the WiFi dongle.Interestingly it doesn't work for me either.
