Did you happen to catch that on a storage scope?
So far, most of the comments seem centered on turning on the scanner and starting the vehicle. What about shut down? I'm no going to switch off the radio every time the power supply is about to go away... and sooner or later, the power will go away unexpectedly (and a sequencer won't help there).
The XT may forget the last few mode changes you've given it, but it wakes right up and resumes operating after a drop-out. I can put all my gadgets on an isolated power source with a master switch, easy to use and protected from transients, but having to use the knob every time is a non-starter (pardon the pun).
BCD536 audio issues-2 - YouTube
I think the point is being missed here. We install 1,000's of radios per year in wreckers. NONE of the other radios / scanners have ever had this issue, including the BCD996XT. These wreckers sit in wait, listening to these receivers, most of the time with their engines off to conserve fuel. When they start their wreckers, the scanners loose audio. And as you can see, after having to turn off, then back on, all of your settings are gone. There is no way they will be able to re-manipulate all of theBCD536's driving down the road going to the call so they can continue listening.
I heard you loud and clear, and so did a few others but unfortunately it seems the majority of posters on this thread have amazingly missed the very critical key points you have pointed.
Everyone please READ HIS POSTS CAREFULLY.
I heard you loud and clear, and so did a few others but unfortunately it seems the majority of posters on this thread have amazingly missed the very critical key points you have pointed out.
It might be you who needs to read carefully.
His problem is being caused by a voltage drop which apparently affects 536s more than it does 996s.
It would appear the 536 is not the right radio for his "1000s of installations", if he's not willing to address the voltage issue properly.
And, now you didn't read MY post.
My comment was directed toward those who kept offering unworkable solutions - such as shutting off all the scanners in the tow trucks before shutting off the truck. cdcomm said several times that wasn't going to fly and yet people kept offering it. I agree that modifying the actual INSTALL may be the only solution here.
I'm anxiously waiting to hear what actually DOES fix the problem.
I'm sure others are wondering what will be the permanent fix for the OP's problem.
Installing it properly so the voltage doesn't drop, meaning it continues to operate instead of loses voltage...
Properly? Meaning a separate isolated battery that isn't pulled down by starting? This isn't an example of proper, it's a vehicle modification which shouldn't be required to install a scanner.
My diesel truck with dual 1000CCA amp batteries will drop to 8v when starting cold, measured at the batteries. Your "proper" install would mean a separate small battery diode isolated from backfeed to the main starting batteries.
My bet is Paul and his group will find a method to either fix this, or detect it and simply reboot the scanner.
Would you connect your computer to a lightswitch?
