I have a BCD996P2 running on a yagi antenna for 9 years now. Broadcasting my feed. Just out of the blue the scanner went deaf. So i took a look at the set up. It turned out that it was no longer picking up the control channel. I checked the programing (it was good) so I put a set top antenna on the scanner and it was working fine. I did however update the programing to add some new channels that were added to the county system. I ten hooked the yagi back up and still not receiving the control channel, I then put the set top antenna on it was working fine. Last night there was a job in the county but nothing on my feed. I checked the scanner and sure enough it had lost reception on the control channels with the set top antenna as well. I changed the orientation of he set top antenna and now I'm good. There has been no new construction near or at the scanner location. I'm lost on what the problem is. If anyone has insight on this I would appreciate the help.
thank you,
Al
thank you,
Al
