Hello everyone, so I've had my scanner for about a week now and love it. It is mounted in my truck and I use it while traveling to listen to trunked systems (NC VIPER) in my area. I've experimented with several different antennas and believe I have found one that has the best results for me, which is a Motorola HAF4017, which is the same antennas that they're using to transmit on. Anyway, usually the signal is clear and I have no issues, But sometimes during the middle of a transmission the sound will start getting choppy and cutting out like a bad cell phone connection. However I feel it happens to frequently to be just a dead zone or weak signal from a tower, sometimes it happens when I am pretty close to a tower. I did a lot of reading on other threads and found that adjusting the P25 threshold may solve this issue. It was set to auto by default and I read to enable the error rate display and leave it on a specific talkgroup for a while to let it self adjust the threshold and then manually set it to that. Which I did while stationary at home, it kept hopping between 9 and 10 with errors on both but stayed on 9 after transmissions were over, so I manually set it to 9 even though it still shows there are errors, I cannot find a setting that has 0 errors. But I am still experiencing choppy audio during transmissions occasionally. I have noticed that when I am hearing the choppy audio the error rate shoots up into the 100's. Does the manual threshold have adverse effects when using on a mobile setup. Since I am driving should I just leave it on auto and try adjusting something else? I appreciate everyone's input! Here is a link to a short video I took which shows the error rate.
Video
Video
