BCD325P2/BCD996P2: BCD996P2 skipping over two tone paging
wqhz937
I’m having a weird issue on my 996P2. On only one analog frequency, when they’re sending a two tone page over the air, the scanner keeps scanning right over the channel. Once the tones stop, it picks up the channel immediately. Has anyone encountered this and found a fix?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Does that channel have PL programmed? They may not send PL when they tone out.
Whiskey3JMC
NI NI NI
Simulcastylvania, TE
Yes I know a few counties who only send the PL out when the voice dispatch begins. Camden County, NJ is a notable example of this. Take the PL out if programmed
wqhz937
Thank you everyone. Yes, the PL is programmed. I’ll remove it and see if it improves.
wqhz937
Finally had a call come in while next to the scanner. Removing the PL did the trick. Thank you!
