Hello Everyone. I recently purchased a Uniden BCD996P2 scanner and using the ProScan programming software. I have programmed and reprogrammed this unit multiple times with no result. I haven't received or decoded any P25 signals. I thought that programming motorola radios were crazy, but this uniden scanner seems worse lol. I have also tried the FreeScan programming software with the same results. I have only received FM analogue signals. This is so disappointing.
Imported the database from RadioReference and loaded it to the radio.
Can anyone in the Toronto Ontario area using the same setup share their programming file with me so I can read though and see what am doing incorrectly.
Note: Am new to this uniden scanner system and that the scanner does not have DMR/NXDN.
Thank You
Thank You
