scannerowner
Can I use the programming cable with an extension USB cable?
-Can I use the programming cable with an extension USB cable?
-Yep that's the one on Windows 10. Does it have to have anything special with the chip set or anything for the driver?
You will either have to purchase a new USB-1 cable, or follow this convoluted procedure for the old one.
It does work, I've been using my older cable on Win10 since Microsoft released it. One caveat... on some of the larger Win10 updates, you may need to quickly run through the driver procedure again to re-install the older driver. Once you have that driver download stored on your computer, and used the procedure a couple of times, it takes less than 30 seconds to re-install the older driver if needed after a Win10 update. If you can't get this procedure to work, there is no other work-around for the older USB-1 cable.
Download the "PL-2303 Vista Driver Installer.exe" from the following link, make sure you download the first file on that page.... the one dated 10/22/2006.
Uniden | A World Without Wires
my.uniden.com
Run that exe file to install the drivers on your computer, and then restart your computer and connect the cable to just your computer.
Next, open your "Device Manager", and under "Ports (COM & LPT)" look for an entry for the cable... it will most likely have a yellow exclamation point and a note about the PL2303HXA chip being phased out.
Right click on that PL2303HXA line, and select "update driver", then select "browse my computer for drivers".
Next, select "Let me pick from a list of available drivers on my computer", then highlight the top driver (the oldest one) in that list, "Prolific USB-to-Serial COMM Port Version: 3.2.0.0 [7/31/2007] and click "Next".
Now check under the "Ports (COM & LPT)" and see if the "Prolific USB-to-Serial COMM Port" is listed there with a port number assigned to it.
If you now see a port number assigned to the cable, your cable is working properly... now you need to set up your software to connect to that port number. Any issue you have getting that to happen is a software issue rather than a cable issue.
That should work, the description indicates that it carries power and data.Reopening this thread, but can I use this as an extension cable?
UGREEN 2 Pack USB Extension Cable, (3 FT+ 3 FT) USB Extender USB 3.0 Extension Cable Nylon Braided Compatible with Webcam, Camera, Phone, USB hub, Mouse, Keyboard, Printer, Hard Drive, Headset, Xbox https://a.co/d/5UCW69Z
