BCT15X Help
WQJQ863
Can't Follow Simple Instructions
how do i remove alabama from a bc15x i dont want alabama i want to scan my system
W8RMH
Feed Provider Since 2012
From Mark's BCT15X Easier-to-Read Manual
The most frustrating thing about this radio is right out of the box, all BearTracker features are on by default which makes no sense at all if you don't know how to turn them off. My advice is to disable everything and start from there.
Press POL and HP until all the icons (PL, DT, HP, and BT) disappear from the display to turn off all preprogrammed frequencies. This will give you 'Nothing to Scan' in the display. Now you can jump into programming your frequencies.
The scanner includes state-by-state preprogrammed frequencies designed to provide you with good general radio coverage targeted to the state you are in.
Press POL once to turn on a state. Press then VOL. Scroll to 'Your State' and press E/ to save and exit. Press POL until all icons disappear again.
