bcTool and EDACS possible bug
jeffww
I've noticed that bcTool fails to set the "TYPE" for EDACS system imported from RadioReference.com I originally noticed this issue about a year ago. I'm currently using 2.0.0.916. I've compared this to ARC996 and it does retain the proper type when downloading a system from radioreference.com and programming the scanner. I programmed with ARC996, then imported from the scanner into bcTool and noticed it did show the proper type, so the problem is most obvious when downloading from the internet.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Jeff, I think the best place to report bugs like these are in the forums that the gentleman that has written BCTool has set up - there's both a Yahoo group and a Tender site, the links for which can be found here...
BcTool - The RadioReference Wiki
As the gentleman is in the UK, I suspect he'd be watching these areas more than a US based board...HTH...Mike
