Beartracker 885 Power Switch Replacement?
AdamWRJN246
Sioux Falls,SD
@Trucker700 , Seen your post on the Uniden Bear Tracker 885 power switch wanted to reply but it says no one can reply to that post anymore so I had to reply to this post. I am having the same issue with intermittent operation. Could you please post the part# and where you got the replacement switch (ie. Website address). Thank you.
Trucker700
I purchased the On/Off, Volume /Squelch control from Uniden Parts. That was several years ago. I don't have the part number anymore. I did do a search on Uniden Parts website for a replacement control. Unfortunately, the only one that came up is on back order.
I will continue to look through my documents to find the exact part number from DigiKey for a replacement control from them as well.
Sorry I don't have a better answer for you right now.
James
Trucker700
For future reference, here is a photo of the tag with the part number from Uniden for a replacement on/off, volume and Squelch control that works with the 885.
