Being Driven Nuts!
buggiecar
W1COD
W.Hartford,CT
Hey group,
This CT system is a real brain buster...Using the Hartford Group of frequencies for Bloomfield...I an still having State PD and Hartford Fire sneaking in on me even with only Bloomfield programmed into the radio...it's a Uniden 536HP...has anyone else
CT
n1chu
Farmington, Connecticut
Dynamic talkgroups? I don’t believe I’ve ever heard these. I always use ID Scan… is that why I dont hear them? Or does CLMRN even have such a thing?
buggiecar
W1COD
W.Hartford,CT
So in otherwords Doc...I shouldn't bother to put in the talkgroups since they are dynamic?
W1KNE
Not a forensic scannist.
New England
check to make sure it's in ID scan mode and not ID search mode.
This sounds like the most plausable cause. When scanning CLMRN, if it says "ID Search", that will tell you. To switch to ID Scan, simply while scanning CLMRN, press Function then Enter. It will toggle it back.
Reconrider
Inside the Galaxy
Radio Galaxy
Any group 65000 and above are talkgroups for anyone who “roams”. I hear Waterbury a lot on them. I see a lot of enc groups as well. I have them all locked out
Reconrider
Inside the Galaxy
Radio Galaxy
No. 65000 and up are random users. They can change at any moments notice. I would suggest lock them out of the database with the program software that you use to program it, or don’t use id search like doc has mentioned
CT
Here's an advanced tip for you who operate in ID Search Mode.
I create a group called "Ignore" and enter the various ID's - then lock them out.
I also assign a quick key to the group that I don't enable.
It looks like this:
Reconrider
Inside the Galaxy
Radio Galaxy
It looks like this:
I do the same except On the sds i have a dept used dedicated to locked out stuff. I named it “blocked” lol
