camacho_13
Best antenna for Uniden sds200???
I have had good luck with the following antennas:Best antenna for Uniden sds200???
For mobile operations:
Larsen NMO150/450/758 Mobile Antenna Tri-Band 150-165,450-470,700/800MHz
Tri-band antenna covers 150-174, 430-520 & 750-870, 100 Watts, Whip Length 16.5"theantennafarm.com
Tri-Band 150-165, 450-470 & 806-940 MHz Mobile Two Way Radio Antenna Scanner
Tri-band antenna covers 150-165, 450-470 & 806-940, 100 Watts, Whip Length 16.5"theantennafarm.com
EM Wave EM-M43002 - Triple Band Mobile Antennas
Tri-Band 150-162/450-490/763-870 MHz IP67 Rated Roof Mount Antennatheantennafarm.com
A mount will be needed for the mobile antenna: Mobile Antenna Mounts | The Antenna Farm
What he said. I have one of these about 20' up.I have excellent results with LMR-400 and the DP Omni X antenna. A bit expensive but outperforms (over multiple bands) any other antenna I've tried.
OmniX Scanner Base Antenna
Scott
What is the difference between the two Larsen antennas?
Thank you Sir.The NMO150/450/758 version has a spring on the base and a more flexible whip.
The NMO150/450/800 is an older model, no spring and a stiffer whip.
Either one will work fine. If you have a taller vehicle, the -758 would be a better choice.
You can often find the -800 version to be less expensive.
Can you use one of these mobile antennae's for a SDS200 Uniden base?
I think Steve9570 was referring to a window mount home air conditioner unit. Some will sneak the coax out around that and drop the magnetic mount on top of the unit.Thanks !Stupid question but what are you referring to as A/C unit?
I can't determine the coaxial cable length. Any idea?
