What is the best magnet scanner antenna that I can put on my trunk on my car? Which has the best reception?
scannerman200 said:What is the best magnet scanner antenna that I can put on my trunk on my car? Which has the best reception?
LOL, its too bad some of us wouldnt dare drill a hole in our cars, i wish i could take advantage of thatn8chb said:Magnetic-Mount and through the glass type moble antennas are capacitive inductive and have no RF ground.
Best type is mounted through the metal and they take advantage of the vehical mass and work 10 times better.
73
Roger
NightFox said:Here's one that I have been using for about a week now. Not sure how well it will compare to others, i'm still pretty new to the scanning world.
http://www.radioshack.com/product/index.jsp?productId=2102469&cp
It has a receive range of 25mhz-1300mhz and has a 16' cable terminated with BNC.
At VHF-hi and UHF, a properly designed mag mount has pretty good coupling to the roof of the car. In fact, at UHF and above, a 3" diameter capacitor plate is almost a dead short to ground - certainly only a tiny part of the radiation resistance of the system. You lose more signal mounting a drilled-in antenna on the trunk lid (it's about -5dbr [db from the roof]) than you do from a mag mount in the center of the roof. I'd worry more about 15 feet of RG-58U at 450 MHz (~1.5db loss).n8chb said:Magnetic-Mount and through the glass type moble antennas are capacitive inductive and have no RF ground.
JHaislet said:Is there a simple way to RF ground a magnet mount antenna to the vehicle? For example, a small jumper attached from the magnet mount to bare metal on the vehicle?
NightFox :NightFox said:Here's one that I have been using for about a week now. Not sure how well it will compare to others, i'm still pretty new to the scanning world.
Another thought, find a mag mount base that is NMO so that you can use the antenna of your choice for the frequency ranges you want to receive. If you have problems finding such, let me/us know.scannerman200 said:What is the best magnet scanner antenna that I can put on my trunk on my car? Which has the best reception?
What is NMO? An how is it mounted? I see that alot in anntenna forum.RISC777 said:Another thought, find a mag mount base that is NMO so that you can use the antenna of your choice for the frequency ranges you want to receive. If you have problems finding such, let me/us know.
NMO is New MOtorola mount. It comes in just about everything - mag mount, cowl mount, flat (roof or trunk lid) mount, trunk lip mount.Navycop said:What is NMO? An how is it mounted? I see that alot in anntenna forum.
Basically, Navycop, it's a threaded connection: 1-1/8" 18 thread.Navycop said:What is NMO? An how is it mounted? I see that alot in anntenna forum.
