Best Mobile 2025
slowmover
Fort Worth
A general: what should I recommend to friends who want high performance in Citizen Band?
Let’s ballpark it at $500 entry.
Will last longer than the time they own the automobile.
Seatbelts, Concealed Carry, and CITIZEN BAND.
This thread aimed at YOU, not the guy who knows even less. However little you know, the tools are linked as to WHAT and WHY. Your handle on them makes it easier for your buddy to understand. (You don’t just toss him in and expect him to swim).
1). As a way of taking what Best Mobile 2023 unveiled regarding the revolutionary jump in RX/DX performance:
2). Then allying this to the major problem in traveling the USA while constantly monitoring AM-19 for potential problems, not just camaraderie to while-away-the-hours:
3). To up one’s game in Who, What, Where after an install:
4). Comes down to having a first class installation featuring modern gear, and
Making the best choice as to:
A). Antenna & Mount
B). Location
C). A high fidelity external speaker.
— The key concept is that a mobile radio rig is a set of systems which must perform well in & of themselves.
The Amateur Mobile Radio Installation Bible
is main reference. Followed by examples in this sub-forum (the one in which you’re reading; and):
As to antenna (reason for this thread):
That I think will settle out past the OP questions to I.D. what may be best re a 6’ NMO-mount, roof-center antenna as this represents above 85% of what a no-holds-barred roof system is capable.
The transceiver itself is automatically an NRC-equipped AM/SSB model with a number of choices, but lets narrow it down to those having enough wattage to Hear, and Get Heard as is possible where TX & RX are equivalent. (Up to, but not needing more than, 100W. 50-80W covers the necessary and makes easier the installation):
To that I nominate the ANYTONE 6666-Pro as spec plus size are the aces. This is significantly smaller than almost all its peers (stays inside budget proposed).
Speaker (of course) is the DRIVER EXTREME DRX-9010.
Antenna can be removed and mount capped.
Radio installed in dash or console can have microphone removed.
Result is that “radio rig” disappears.
slowmover
Fort Worth
Complaints:
Not gonna cut a hole in the roof”
Is now followed by,
Not gonna cut a hole in the dash or console”.
I’ve done both. One is reluctant first time.
I’ve gone to PETERBILT parts counter to pay $165 for a console face cover to replace the one I’d clearanced for a radio. Or scrounged the junk yard for the same piece. On trucks I didn’t own.
There’s usually more room behind these than is first apparent.
The permanent installation is the one that gets used.
How and where to run cabling (power or coax) is found by some common sense having read the reference work linked above; and done searches for models to follow in the other subforum (a pickup is a pickup, generally).
Sure, could be mounted otherwise. But these ideas should lead (and being able to glance at face is best).
Speaker can go here though it’s not as good as B or C pillar.
slowmover
Fort Worth
Whether it winds up being NMO30 or NMO34, add springB (2.5”) to this with the 64” W640 whip to top out near 6’.
These antennas are low key, practically disappear compared to a CB antenna as it’s usually considered.
Get the cap so when removed the mount is covered.
My opinion is that 7’ is where the magic happens. But it’s not desired for this budget and set of tastes.
From 6’ to 7’ is this (actual experience): the man speaking at the far reach of my Receive with a 6’ changed to I could now hear to whom he was speaking when I swapped over to 7’ (two pairs of Skipshooters in those lengths; while parked).
I don’t think it’ll matter enough that change versus the simplicity of what’s recommended here.
slowmover
Fort Worth
This is the retailer from whom I’d buy.
Specify MARS/Alignment.
He’s been field tester among several for the factory and knows these as well or better than almost all others the past three years.
