Best scanner for aircraft only
Menifee, CA
Just ran into this thread, the 15X is SOLID scanner for CalFire scanning. You won't find better. It's fed my live fire scanner that pulls in Air Tactics FM, Air Ground, and Rotor victor AM freqs like a champ, day in and day out, for maybe 15years, after it replaced an 895xlt. Throw some decent ears on it (or even an unfolded coat hanger) and you'll be set.
And unfolded coat hanger? I assume that would have to be soldered onto a BNC connector with some kind of plastic insulator.
737mech
Clark County, NV.
Abosulutely agree here, BCT15X shines above BC125AT (BSD435HP and SDS100 for this ranking on airband), so I brought 2nd BCT15X for both rooms. The only thing I have complaint about BCT15X is when listening via earphone (in bed), it has constant scanning noise not heard from speaker. And BC127AT is quiet via ear jack. all 3 BCT15X units has the same scanner noise from ear jack (3 because I returned my 1st BCT15X purchase due to this noise, only to find the next 2 purchase from different production year being the same).
BTW I found my SDS100, when listening DMR, has similar noise from earphone jack, but not when listening P25 or for this thread, the air band.
Using a simple inline ground loop isolator will take care of that earphone noise.
Menifee, CA
This noise that you speak of in an earphone is the same noise I have pointed out coming over different feeds from broadcastify. I guess those people need to put a filter in line with their audio output? It's a constant tick tick tick and you can hear the computer noise. It's also got a hiss to it. It's not a 60 Cycle hum.
Icanhearit
Bay Area, CA
Not sure if is the same noise. My noise is the scanning noise. If I lock to a specific channel without scanning(as broadcastify feed normally does), then there is no noise. I do hear people say if using ground loop isolator filter, then the signal open/close will have a click (so it actually means those feeders have a filter in place)
Menifee, CA
That is what I'm referring to. The scanning noise. I've heard it on many many feeds and I'm wondering if it's specific to any particular scanner. I see the noise filter and it is intended for a 60hz hum which is caused usually by the cable of the wall wart acting like an antenna and transmitting a 60hz hum that the scanner picks up in the audio section. I only know half of what I just wrote. My ham elmer gave me that information. Lol. He was telling me that you can also get it by running your power supply line in close proximity to your audio line, like maybe using wire ties conference a need appearance when they actually need to be crossed like an X to cancel out the noise. I guess the nice filter works based on reading other people.
AB4BF
EM93cs
I don't want to break any rules and cross post. I hope it's okay to start in this group. If this would be better in an equipment group I'd appreciate it if the moderator would guide me.
Due to the large number of fires down here in Riverside County with Cal Fire and Forest Service, I would like to choose a dedicated scanner that does well on the aircraft band but of course also does well on VHF High. A ham I know told me that an older scanner might be good except for the Bearcat 780 that he said has "low audio recovery?" Is there an older radio that excels on the aircraft band or is there a current scanner like the BCT 15X? I like the Unidens. I've noticed these older scanners are kind of pricey on eBay for used ones like the owners are trying to get what they paid for them. I'm not going to spend $300 on an older technology radio when I can spend $50 more and get a 996.
I was further told that a discone antenna would be good for this but I don't know one antenna from another. Well that's not completely true but I don't know about a discone. I am especially interested in hearing the attack helicopters.
I'm dealing with the wife factor now and she may leave me for the Milkman if I don't watch it. I don't want to pop for another 996P2 if a $150 radio will do what I'd like.
Hello, I'm using 2 Radio Shack Pro-2052 scanners (made by Uniden for Radio Shack) for aircraft. Yep they are old and analog but they scan 100 channels per second and will receive military air frequencies as well. They are hooked to two discones which I can switch as needed, if needed. I took one of them one Tuesday morning (Tuesday seems to be the busiest day for commercial aircraft), put it to search scanning aircraft frequencies and found 70 of the most used frequencies. I entered those and the scanner never stops. I also do not use the delay function on air to ground because most signals are one sided, the ground control is not receivable. However, I do have local airport frequencies entered and they are on delay.
My discones are mounted in my attic about 25 feet off the ground and my house sits about 550 feet above sea level. I have received aircraft flying over the Rockies, aircraft coming up the coast of South America, and military aircraft all over the eastern and midwestern US.
These scanners are getting harder to find and the costs of the used ones have slowly risen. I have 3 and one is sick right now with a bad capacitor, but if I ever catch up with my chores, I'll fix it.
AB4BF
EM93cs
What make of Discone antenna are you using with that Pro-2052 scanner.
One is like this, but I believe the manufacturer was Comet.
The other is a 3 element discone, 6 elements total, I can't remember the maker, got it as an open box item from R&L Electronics. Looks like this:
lu81fitter
Marshall County, Illinois
If you are solely looking to monitor the fire stuff, go get yourself the BCT15X and pair it with this.
Then attach a 1/4 wave whip for VHF to it. (approx. 18 inches)
Mount it on any pole that gets it away from obstructions. You won't be disappointed.
The Antenna Farm can also make a custom cable to go from the radio to the antenna. They are good people. Have done business there many times.
eorange
♦Insane Asylum Premium Member♦
Cleveland, OH
I use the BCT15X as my mil air base, but it definitely misses some transmissions. I also run an AOR AR mini and it's parked on 260.900. I hear extended transmissions on the AOR while the BCT15X just scans on by multiple times and rarely, if ever, stops on 260.900. Each radio uses separate antennas which are exactly the same model in the same location.
eorange
Cleveland, OH
I don't know; I don't use it for civilian VHF airband.
I can say this: older receivers do way better overall. I also recently picked up an IC-R2 and a VR-120 (both in excellent condition and cheap) and they are hotter on mil air than the BCT15X. Way better at pulling in distant signals. I'd take those 2 any day over, say, a BC125 which I don't own but have used extensively for mil air.
xms3200
Cleveland, Ohio
Do you think those receivers might be different when receiving VHF as compared to UHF military, I had an Icom R6 that I returned since it was disappointing on VHF air.
eorange
Cleveland, OH
In my experience VHF sensitivity is never less than UHF sensitivity in the airband. I also have the R6 and it does really well on the VHF airband for me.
jaymatt1978
Cape May,NJ
I have (2) 996T and a regular BCT15 all hooked up to the same antenna and I can tell you the 15 definitely misses transmissions. I don't know about the BCT15X or 996XT. I just did a search on eBay and there's a 996XT for $230 which isn't that bad. For military air only I would go for a BC996T
eorange
Cleveland, OH
That's interesting about the BC996T and good to know. It's impossible to know what you're not hearing unless you have another dissimilar radio. Also, the 996 could certainly be better than the 15...but only maybe in a certain frequency range. (I don't know for sure, just illustrating a point.) There's just no way of knowing - given the very wide mil air range - and one can go insane trying to find the best radio, which we know is unrealistic.
My BCT15X sings pretty well on various mil air freqs, but as mentioned above I've begun to park various radios on a single 'important' freq to ensure coverage.
All good stuff @jaymatt1978 , thanks for the input!
Ubbe
Stockholm, Sweden
You also have to remember that some scanners are very sensitive but cannot handle big signals and other scanners are the opposite.
VHF AIR goes down to 118MHz or even 108MHz and then also pass a big chunk of FM broadcast signals. What scanner that works best probably depends of how high level of FM broadcast signals you have to fight.
My Icom R2 are super sensitive, the most sensitive scanner I have measured with a signal generator, but as soon as I connect it to a roof antenna that sensitivity are gone and are up 100 times worse due to overload issues. When a scanner receives a too strong signal it will start to gradually loose sensitivity without showing any other signs of overload. A BCT15 doesn't measure as well as a R2 but when connected to a roof antenna the BCT15 hardly reacts at all and keep its sensitivity, that then will be way better than the R2. A scanner that doesn't have any impact from big signals are Pro-2006, but then its measured sensitivity are the worse I have seen. The Icom R1500/2500 are also almost immun to big signals and have a better sensitivity than Pro-2006 but are also a more modern receiver.
When monitoring VHF AIR, and most other frequency bands, a FM trap filter will help to reduce overload issues but best are to use a scanner that can handle big signals. Only if you monitor far from any high power transmitter can you use those extra sensitive scanners without loosing sensitivity. If one scanner where good at both sensitivity and overload handling we would all buy just that scanner for analog monitoring. But usually you have to sacrifice overload handling to get good sensitivity specification in the price range that include scanners. Professional radios in the $1,000 range and up are often both sensitive and with good overload handling but they are poor at high speed scanning.
/Ubbe
eorange
Cleveland, OH
I forgot to mention I have a mini circuits FM trap filter inline with the BCT15X only. I do pick up some verrrry faint CAP transmissions in the UHF ARTCC frequencies {280 to 330 MHz) and yet I don't hear 260.900 which can be pretty solid coming in on the AOR. So I doubt the trap filter is killing anything. I am pretty sure it's helping quite a bit, because I hooked up my R30 to my discone and that's when I realized I had a FM broadcast problem!
