Best scanner for ht750/1250?
casemods
I picked up these radios for a good price and was wondering the best scanner that's capable to use with their programming and features
Brts96
I might be missing something, but the HT 750 /1250 are transceivers. Most scanners should be able to receive what you transmit with them.
Can you please give us more information on what bands your radios are on - VHF, UHF, etc?
In concept, you could use the HT's as scanners. As a best practice, scanners are safest to avoid accidentally keying up on a channel you're not authorized to be on.
Depending on your budget, there are a lot of options. If you have the budget, the SDS 100 would be a good portable scanner for you. There are other models and brands that may fit your needs as well.
What's your use for the radios, including the scanners?
As said, not sure what you are asking here.
Do you understand what you purchased? What do you plan to do with them? Do you have an appropriate license to utilize them?
If you are asking about programming the Motorola HT-750 or HT-1250, you want Motorola Pro CPS plus the appropriate cable.
casemods
CPS says I can program from 403-470mhz. Can they be programmed any differently? And yeah I'm only setting setting up as listen-only in CPS.
Google says 403-470mHz is UHF? Not an expert though.
Just like listening to radio chatter. Mainly stores. I always heard funny stuff at stores. Also, would like to find local stuff not listed on the website registry.
Already got the cable and software, the USB cable seems to work just fine on windows 11.
I also ordered a uv5r-m+ for $30 to mess around with.
Don't know if I can justify the $500 process tag on that scanner just yet. Was hoping for something slightly less costly for a beginner.
pb_lonny
Tasmania
So you have got a couple of transceivers which you want to use as scanners? We have seen this so many times before.
Basically, you are MUCH better off with a cheap scanner, less chance of anything goikg wrong...
casemods
Ok I understand what your are saying now. Maybe I will save up for the sds100
hill
Middle River, MD
If you just want to listen to basic frequencies and no digital the BC125AT handheld scanner linked below would be great for your uses. A SDS100 would be way overkill. If you only want to monitor analog and not digital or Trunking.
Also can only do Low Band, VHF and UHF. It can't do 700/800 but those bands are mostly digital anyway.
You will get 500 channels that can have alpha tags added to each channel, so you will remember it's use.
I use this very scanner for monitoring Mil Air and great for that task.
steve9570
Member WSAG-457 -KB1-KZW- KCP-2441 CB-WA1-BZG
Natick Ma
Also be aware the HT 1250 can "scan"only 16 channels.
I have mine right in front of me now. Works great but has its limits.
No lock out of channel etc.
Steve
kb9klc
Look around for a used basic scanner, one in my area sold for 30 bucks on FB marketplace a few days ago, way better for trying to find the "stores" around you than either of the radios you have mentioned. The SDS stuff is way over kill for that sort of scanning and honestly on analog VHF and UHF doesn't work as well as some of the older stuff.
bearcatrp
Land of 10,000 taxes
You would be better off with the Uniden 160DN for $249.00
Golay
I may have to respectfully disagree depending on what the OP wants to listen to.
To be honest, if all I wanted to hear is conventional comms on one band, I'd rather have a commercial transceiver with a drop in charger. Makes life easier for that one scenario.
rf_patriot200
Freeport, Illinois
You Should be able to program the GMRS simplex and repeater channels, as well as 70cm ham repeaters, if you have a interest in those BUT ... DO NOT Transmit until you're licensed. If those radios have Zones, then you can program a lot more than just 16 channels.
casemods
They have zones but I have no idea how to set them
rf_patriot200
Freeport, Illinois
Ok, I'm not familiar with that model, but with the software, additional zones are probably obvious. I have a Xts2500 and a Xpr6550 which have 16 channels in each zone, but up to several zones. and then of course the Scan feature, when active will look like a "Z" in the display.
casemods
Yeah I figured out the scan and the nuisance delete feature but haven't looked into the zones yet. I will try to do some research on it, thanks
NewJerseyOldListener
Therefore, if the OP wants to sell the Motorolas, I would buy them.
