Hi there, for the last 9 plus years I have been proudly feeding the Newington, Connecticut, Police Fire and EMS to Broadcastify / RadioReference.
I currently feed the site using a Uniden HomePatrol 1. I have an offsite backup that automaticlly connects if my feed goes down using a Uniden BCT15X. This setup have been working GREAT for me for years.
My towns feeds will soon be moving from its Analog LTR trunking system to the Connecticut Land Mobile Radio Network (CLMRN) system which uses P25 Phase II system. (Connecticut Land Mobile Radio Network (CLMRN) Trunking System, Statewide, Connecticut) which means my setup I am using will no longer work.
I am looking to continue broadcasting the Newington system when they switch. I have met and talked with the Chief of police who has assured me that he wants to see the routine calls be made available to the public and told me that the routine calls will not be scrambled. He also told me that calls from surpervisor to suprvisors may be encrypted (I iam ok with that, and they do that now). They have ordered the new digital radios and they will go into use this fall.
So what I am looking for is what is the best setup to do this without breaking the bank.
I have looked at the Homepatrol 2, the BCD996P2, the SDS200, the P25RX, SDR Dongles and so forth. I am told I should not use the Homepatrol 2 becuase of Simulcast issues (which I don't understand but thats ok.) I have worked with SDR dongles and got SDR Trunk to work. I want something that is easy to setup and let it run. (Set it and forget it) The ONLY thing this this is going to monitor is that feed, so I don't care if it stores a million channels.
I just want to send my feed to Broadcastify (and hear it locally when I am near it like I do now)
Now to add one more wrinkle to things, should I also be sending to "Broadcastify Calls" and can I broadcast to both the standard broadcatify service and Calls at the same time from the same device?
I also notice that my local Connecticut State Police (Troop H) is not being broadcast on Calls while all the other troops are... Maybe I should broadcast that way too.
So what kind of advice can people give me so that I offer the best quality and again without breaking the bank? Thanks!
