Best Software fir SDR Play?
LubeckTech
Parkersburg, WV
I just got an SDR Play used on Ebay and am looking for recommendations as to which software will let me exploit it to it's fullest. I am experienced with SDR dongles and mainly use SDR# but have experimented with others. Currently I have it running with SDR# which I downloaded from thr SDR Play website. I think mine is an older one because it has an F connector and light colored case instead of the black case and SMA connector I see in newer pictures.
br0adband
Springfield MO
You have the 1st gen original model of the SDRplay as noted by the color of the casing and the F-connector but it should work just as well as the newer model with the black casing and SMA-connector. Internally I believe they're basically the same hardware (not 100% sure on that, however) so there shouldn't be any software compatibility issues except for SDR# usage which requires you to use build 1361 - newer builds simply won't connect to SDRplay to make use of it (when SDR# is running the titlebar of the window will plainly show you the build/version number).
If you don't already have it, there's a link at the SDRplay forums to get build 1361 as well as all the plugins that work with that build too (separate archive downloads).
N9JIG
Sheriff
Moderator
Far NW Valley
I have had a great experience with HDSDR. Using the step-by-step instructions from the SDRPlay website it was easy to install and works great.
I have diddles a bit with a couple others but so far I still like HDSDR best.
