Best Tri Band antenna for SDS100/SDS200
sparty1984
I want to listen to brodcasts in the 120s, 150s, 440-450s and 700-800s
I have remtronix 920s, but it is very weak on the 120s and 150s and I am hoping there is a better option
hiegtx
Mentor
Dallas, TX
Take a look at the Remtronix triband REM-842S,
It does better on the Vhf-high in my area, and while it's not as "focused" on the 700 & 800Mhz used by most trunked systems in my area, it does not cause me to "lose" the ones that are of interest to me in my specific area.
If you are using the SMA-to-BNC adapter, so that you can switch "horses" more easily, there is a BNC version available.
sparty1984
that's the one I found, it doesn't specifically say 120s but I haven't found ANY that say that. this is looking like the Best Option.. Thanks for the Reply!
hiegtx
Mentor
Dallas, TX
120 is pretty close to the traditional "Vhf-High" public safety licensees. Should work well for the aircraft band in the +/- 120Mhz range
dmfalk
Eureka
I use the Comet W100RX, myself. Telescopic, double-jointed, which makes it easy to fold behind my SDS100, and can work as low as 25MHz. (Yes, that's WWV, when it's on during skip.)
sparty1984
would that work outside? I forgot to mention this is for the window mount on my truck1755032108105.png
dmfalk
Eureka
Not meant for window mounts, no... It's meant for handhelds. And yes, you should've been more specific. This way, you'd get better suggestions for your use. (As I don't drive, this type of antenna is something I'm not familiar with, so I can't help you here.)
n1chu
Farmington, Connecticut
It’s been stated the SDS100/200 play better with the 700-800MHz bands. That said, the lower frequency bands can suffer slightly. Suggest an antenna that’s cut for those bands like what Enforcer52 has suggested. They are longer whip antennas which make them somewhat unmanageable but work better across the low bands while still performing on the higher frequency bands.
Trilliumaire
Evergreen, CO
For driving around, or sitting at home, I have been using on the SDS100:
PulseLarsen NMO150/450/800
With the NMO mag mount.
For walking around, the tri-bands I have are:
DIAMOND RHF10 (more for cutting out multi-path, acts as an attenuator to avoid front-end saturation, urban jungles only)
Remtronix 843S (the one with the 0-90 degree bend)
Remtronix 920S (fully sealed, replaces the stock antenna)
As others above mention, while not "tri-band" the Diamond RH77CA (might be considered tri-band on the SDS100?)
As you probably know, you will get better reception with an antenna built for the freq range of interest.
For example, the Remtronix 800B is awesome for 700/800 P25 in my area with my weak reception issues in the mountains. Beats the tri-bands subjectively, but still need to measure SNR (with a SDR) or look at the waterfall on the SDS100 for a valid comparison.
EAFrizzle
Mash Button. Make Far Talk.
SE de DFW, Cabrón
I use a Remtronix 843B on my SDS200 and have have the SMA version when I need it for the SDS100. Reception is as good as any other tri-band I've tried, VHF included. The swivel is nice to lay the 100 on its side if windy. If I need better reception on VHF, I use a ham dual-bander or a telescopic one.
The 920S stays on my SDS100 most of the time. My local system is 700 MHz and a lot of AirMed and ambulance is on UHF, so it works great for that.
prcguy
Since the need covers such a wide range I would recommend one of the public service tri-band 150/450/800 cop types and there are many to choose from. From recent testing done on many different makes and models it appears there is not a lot of difference between them that would make or break reception. With that I find the cheapest of the lot, the Tram 8079 works great and has lasted for a couple of years on my vehicles. Here is a link to an eBay seller with a good price.
EAFrizzle
SE de DFW, Cabrón
I'm using one of those as a temporary base antenna for some scanners. Metal roof makes a great ground plane, and it does a good job for me across all three bands.
Trilliumaire
Evergreen, CO
I am building a rooftop antenna farm for the SDS100 ... emphasizing 700/800 systems.
Larsen SLPT698/960NMO (stubby, cuts out multi path, lower gain / urban situations, mobile version of the RHF10)
PCTEL Maxrad BMAX7603S (general open road 700/800 antenna)
PulseLarsen NMO150/450/800 (mentioned above, general tri-band, catchall antenna)
Switching these three antennas mechanically with the MFJ-2703N (3 way switch).
Expecting the first two antennas to arrive this week. Already using the tri-band.
:geek:
Challenge: Large tent on the roof, limited real estate.
:unsure:
prcguy
:geek:
:unsure:
The Tram 8079 mentioned above will work the same as the Larsen NMO150/450/800 for less than half the $$.
Trilliumaire
Evergreen, CO
I noticed the antennas look very similar ... but I already have the Larsen, it only costs $36.95 online. So only $1 more than the Tram you mention.
vagrant
ker-muhj-uhn
California
That one is the Larsen NMO150/450/800 = no spring
Larsen NMO150/450/756 = spring at base (this costs more)
