Best way to remove a scratch and scuff marks??
sportsfan7700
Tarrant County, Texas
What way do you suggest to remove scuff and a scratch from a pro 107?
It's just a bit annoying when trying to read the display, as it appears to be in the line of sight when reading.
Get a small tube of cheap toothpaste, paste not gel, and a clean microfiber towel. Use a very all small amount of paste on the towel and lightly rub it into the plastic screen until it's dry. Use a clean side of the towel and buff it out. Repeat as necessary until the screen is scratch free. I've also used Flitz metal polish with good results but the toothpaste is more readily available and less expensive.
If the scratch is deep enough you may not be able to buff all of it out but may be able to reduce it to an acceptable level.
