The 1st versions of BKR9000 batteries may develop a problem that could report incorrect capacities after charging. BK has corrected the Capacity reporting error in a firmware patch BKR102 Rev5, and Rev6 I noticed the capacity level was dropping on my Rev5 battery after around the 6th full charge. My radio reported low battery level within a few hours after a full charge after the 8th charge cycle. I disabled low battery audible alert beeps, and TX low power during low battery to help mask the problem, so I could run all day. One night after full charge it was reporting 99% charge 1193mAh TTE 3h 36m. I decided to run it down until it shutoff. Put it on a WX channel volume up, and put it in a pelican case over night. It ran all night and until about noon the next day. After I charged it the capacity corrected by about 50%. Ran it down two more times until it showed 4850mAh. But after about a Month mAh tapered back down. BK has corrected the Capacity reporting error in a firmware patch that must be applied to the BKR0302-2 dual chargers with FW less than 3.0.16. Patched chargers will have a FW version sticker on the bottom. The effected battery characteristic file will update once it's placed in the primary charge cup on your patched charger. The cup flashes yellow around six times, then switches to solid Red. It only takes about 10 seconds, one and done. My battery now report 4868mAh 22h 30m TTE BK Service Bulletin BKSB-1087 BKR0102 Battery reporting incorrect capacity Link to BKSB-1087 -
https://bktechnologies.com/service-po... Applies to: This Instruction applies to BKR0102 Li-Ion batteries manufactured between 2022 and January 2024. Condition: BKR0102 Li-Ion batteries are reporting incorrect capacities relative to the actual capacity of the battery. Correction: Upgrade the battery characteristic file to rev 7. (Most batteries are revision 5). The battery upgrade is accomplished by simply inserting a battery into a BKR0303-2 DUC Dual Unit Charger that has been upgraded to Firmware revision 3.0.16. Requires: BKR0721 CFP Charger Field Programmer with FW 3.0.16 loaded.
BKR9000 Battery Fix video
