BKR5000 Win11 Issues
mont1157
I have been using the same computer to program BKR5000s for well over a year, and all of a sudden, the computer quits recognizing the BKR radio being attached. After turning on the 5000, the computer sees it, but it never appears in the Device Manager, and it eventually crashes the computer causing a restart. I can use a different computer and the same radio works fine.
I hooked up a KNG, and the software never goes green, nor ever sees it in the devise manager, Has anyone else had this happen?
rsmith7799
Arroyo Grande, CA
Have you tried installing the Drivers? BK has a great video of how to do this and instructions. See if this will fix the issue.
mont1157
I did watch the video and tried that. The problem is the computer goes blue screen when the portable is hooked up. A KNG will hook up but it loads some weird version of RNDS. I got a reply from BK Service (they replied really fast), so the thought was WIN11 got an update that has caused it. Going to try some suggestions and see how it works.
I will post the results, and thank you for the reply.
rsmith7799
Arroyo Grande, CA
Your welcome, please send the results.
Project25_MASTR
Monitoring
Texas
I sent them a support ticket three weeks ago for the same thing (BKR9000, as soon as it's plugged in the machine BSoDs) but on a LTSC 2021 computer (haven't heard jack back I will add). My Dells don't do it on Windows 11. The only thing I can think of is either, the 10 GbE NIC is causing issues, the GTX1050Ti is causing issues, or the fact the LTSC machine is a Ryzen processor is causing an issue.
dkcorlfla
Orlando
I doubt the Ryzen processor is the issue; however, it may well use/require a different driver. The blue screen of death almost has to be a driver issue.
mont1157
OK sports fan, the problem is in the Win11 update that came down around March 15, 2025. The only way to fix it is the completely reload a fresh Win11 OS. I have not done that since I have so many radio programs that are older legacy programs that I will have to reconstruct. I did a full hard drive backup, which brought on new problems with Win Backup.
dkcorlfla
Orlando
You can't just roll back the update to the previous?
I also have radio only programs that I run on my Windows 10 computer but it's air gaped (un-plugged Ethernet cable) so I don't have to deal with all this update and general Microsoft nonsense.
Project25_MASTR
Monitoring
Texas
I'd doubt it as both of my work computers are Windows 11 Dells that have been updated. They both work fine. My issue is specifically with a Windows 10 LTSC 2022 machine that is presenting itself with the same syntoms as stated in the original post…radio not recognized, then blue screen.
