Bloomington Question
KB9LIQ
Banned
Central IL
Is METCOM not in use in Bloomington? A friend is getting a job in Bloomington and wants to monitor the local police and fire while at work so I need some help setting this up for him.
KD4YGG
This should get you started...
The 800Mhz EF Johnson MultiNet II system is still in use.
The following agencies are using it:
Bloomington Fire
Normal Fire
McLean County Sheriff
Bloomington/Normal Public Works
McLean County Parks & Rec
McLean County Coroner
METCOM Staff
Other Frequencies (PL tones as noted)
McLean County Fire & EMS Dispatch: 154.190 (173.8)
McLean County ESDA: 453.700 (103.5)
Bloomington PD Dispatch: 453.150 (127.3)
Bloomington PD Channel 2: 453.925 (127.3)
Normal Police Dispatch: 460.025 (103.5)
Normal Police Channel 2: 453.950 (103.5)
McLean County Rural EMS: 154.815 (173.8)
Lifeline EMS: 461.950 ( 88.5)
Notes on METCOM 800Mhz
Confirmed usage of the following frequencies:
856.7625 - unsquelches when another frequency is active
857.7625 - voice
858.2375 - voice
858.7625 - voice
859.7625 - voice
860.7625 - data channel
The best method of scanning this system is to use two scanners in conventional mode as follows:
- Program one scanner with all voice frequencies except 856.7625 and 860.7625
- Do Not Use Delay on ANY of these frequencies
- Program a second scanner with the 856.7625 and 860.7625
- Do Not Use Delay on EITHER of these frequencies
- Program 856.7625 as a PRIORITY channel
- Manually select/hold on 860.7625 and engage PRIORITY function of scanner
- You will hear constant the unsquelch on 860.7625, but if either frequency carries a transmission, you will hear the conversation.
Also, check out www.landofzoz.com for additional Bloomington area info.
