BobCrk
What are the best Bluetooth TX/RX to use with wireless headphones on the scanner?
Hagibis remote transmitter has its own built in battery, less than 2 inches tall long battery lifeWhat are the best Bluetooth TX/RX to use with wireless headphones on the scanner?
There might be a service mode in them, by grounding a pin somewhere, to make the transmitter permanent on for test purposes. If a service schematic are available it should show if there's some sort of permant transmitter key on available.I wish they would add a setting to turn the standby mode off (Always On) on these devices...
Do you have a model number for it? Amazon shows a bluetooth version 5.0 but I believe that those where only available just recently. TaoTronic 5.0I use a bluetooth dongle made by TaoTronics I got off Amazon years ago. Never goes into standby.
I looked on Amazon for it and could only find one that looks just like it by the same company. It's called "upgraded version TaoTronics bluetooth transmitter" and the model is TT-BA01 It is $18USD. Hope that helps! The device I have only has a serial number on it and the original box for it is in my storage unit. It looks just like the one mentioned except the white logo on mine is orange. TT-BA01 AmazonDo you have a model number for it? Amazon shows a bluetooth version 5.0 but I believe that those where only available just recently. TaoTronic 5.0
/Ubbe
Thanks for the info, but that usually means some sort of energy saving feature, as most things these days, and then probably turns off after a short period of silence.It's called "upgraded version
