Bluetooth Programming
70cutlass442
I am looking at buying the bluetooth programming licenses as an alternative to using OTAP or handling each of the 170 portables we need to do.
Is the bluetooth option worth the effort? Does the software do the discovery and pairing? can I simply walk into a room with 40 portables on, pair with them, and start dumping code plugs into them?
Any input is greatly appreciated.
kd4efm
EL98 Florida
Multi write Bluetooth, yes. 10 at a time.
Third of the time of OTAP so a little faster.
70cutlass442
How does that work? Can I use a single programming file and just overwrite the radios current programming without altering the radios native NXDN ID or alias?
kd4efm
EL98 Florida
It's called consecutive write.
To see it, hit write, then hit the check box for it. Bluetooth multi write will do the same thing.
