Bluetooth Speakers for ICOM Radio
richardrosa
Greetings All,
I would like to use an external Bluetooth speaker with my ICOM radios (IC-R30 & IC-705).
I currently have an Anker Soundcore that does NOT seem to work with either of these radios.
The speakers will pair with both radios, but no audio gets transferred.
I have a headset (Prtukyt 6S) that functions, so I'm certain that the ICOM's Bluetooth is OK.
Can someone recommend a reasonably priced Bluetooth speaker that the ICOMs can communicate with?
Thanx.
Richard Rosa
G7RUX
Greetings All,
Thanx.
Richard Rosa
This sounds like an excellent idea because the audio output from the built-in speaker, although crisp, is quite low volume.
W6VVM
I don't see the 705 having BT, what BT transmitter were you using with that?
I’m a bit late here, but it does have built in Bluetooth. I’ve used mine with Apple AirPods and I also bought one of those Pryme RSMs. I will say the Bluetooth range is poor on the 705. Regardless of the Bluetooth device I use, I can’t get more than about 6 feet from the radio without the rx audio breaking up.
