BNC Antenna Advice
rcillig
Omaha, Nebraska
So I bought a nice I was told new in the box never used Whistler 1065 from someone off FB Market Place Estate Sale via PayPal so I can recoup my cash if needed but anyways on to the issue. It arrived and I got her programmed and went to use her and when I hooked the antenna up I noticed the BNC for the antenna is really wobbly, so but she still worked just fine. So I decided to find out why it was loose. After taking it apart and finding out someone had spun the BNC connector around to where the nut inside was loose and so I tried to tighten it up, but I can only get it so tight before it strips out and is loose again. Now everything is still soldered and working so I really don't want to dive into replacing the BNC or taking it off to rethread it if I don't have too. My question is do you guys think if I got it as tight as I can then but something like nail polish, epoxy, superglue of it, that it would hold? Any idea or advice would be awesome.
Rob
KB4MSZ
Billy
Tampa, Florida
I would leave off any of the stuff you mentioned. Those won't hold over time and could cause connection problems eventually. If the connector is holding it's own well enough then let it be. If it has a continuous problem with loosening then it needs to be replaced. That's my opinion on it.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I would just adjust until it is snug and leave it alone. Adding any gunk or liquid to it might be detrimental to performance or, at least, messy when you have to change antennas. Just sayin.
JD
kf4anc
rcillig
Omaha, Nebraska
thanks, guys ya tired to doing nothing and with just the cable weight pulls it out. going to try the hot glue, that is a good idea and if it doesn't work it will come right off with little to no mess. I'm not really confident on soldering on the circuit board as there is a tin housing around it that would have to be removed before I could fix it. If it was just the BNC connector I would be right on replacing it.
rcillig
Omaha, Nebraska
here are a few photos of it, could I just solder it to the case to keep it tight? The tin housing would have to be removed to replace the BNC connector and I'm sure id fudge it up.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I use Gorilla Superglue, holds fast and quick to metal, plastic, wood, etc. Just a tad bit at contact points if you have to glue it.
slicerwizard
Toronto, Ontario
Exactly. Hot glue on metal is completely reversible.
jaspence
Michigan
You need a cable made with RG174 to connect to your main coax. The 174 will put very little strain on the connector. I use this method anytime I connect a scanner or HT to regular coax.
cmdrwill
So Cali
The nut on the BNC connector has backed off, and you may be able to tighten it from the inside with a screwdriver on the nut.
rcillig
Omaha, Nebraska
ok so the glue didn't work, does not get a good signal, guess I got to remove and replace it. I'm not very confident in soldering on the board and that is due to I'm not sure how to remove the silver tin cover so I can gain access to the BNC connections.
KB4MSZ
Billy
Tampa, Florida
Here's my guess on the metal shielding. It likely has tabs in several places along the bottom which project through the circuit board, and then are twisted from the other side to secure it. Worse case would be that the tabs are also soldered to the other side of the board. Hopefully just twisted.
rcillig
Omaha, Nebraska
There is a tin box on the other side also. Ill get a few pics up posted here is a bit just got home from work.
foxtail
Niagara Region Canada
Looking at the pic in the middle, to me that may be a ring with a tab on it.
Not a nut that you think it is. Could be completely missing?
Ubbe
Stockholm, Sweden
You see in the third picture that the nut have come loose and are resting on the jumper from the connector to the circuit board.
/Ubbe
