Brand new here
Charlotte, NC
Hello to everyone. My name is Kyle. 48 years old in Charlotte NC. I’m just starting to really consider getting my ham license soon. Been a radio fan since I was a little boy…always had scanners etc. I just recently purchased a BaoFeng UV-5R (hey it was cheap and I really just thought it was cool!!) but I’m having some trouble finding things just to listen to for now. Any help would be greatly appreciated. I look forward to diving more and more into this whole radio world I’ve always been so fascinated with. Thank you again for any and all help….
brian
DB Administrator
South Carolina
Welcome to the hobby. As with all communication technology, radio technology has advanced significantly in the last 2 decades or so. And that applies to public safety communications also. In the Charlotte area, almost all local public safety communications (assuming that's what you're interested in listening to) is on a digital trunked radio system. State agencies mostly use a different but similar radio system. You'll probably need the most expensive scanner available today to be able to monitor the County system reliably. There are other less expensive non-scanner options for listening.
And there are other things to listen to - businesses, colleges and schools, aircraft, amateur radio, utilities. Some of these monitoring targets use different forms of digital radio systems. My advice is to decide what it is you're most interested in listening to, researching the type of radio system(s) those targets use, and then research a monitoring device/platform that suits your preferences. Doing this in opposite order (purchasing a device, researching, and then deciding what you're able to listen to) often leads to disappointment.
There is a ton of information on this site, and lots of willing folks to answer specific questions you may have. Good luck.
IcomIcR20
Like Brian said, you will not be able to hear much in terms of public safety in the Charlotte area with a UV-5R. You can try 156.165 as Mecklenburg FD was simulcasting their traffic on that frequency at one point. I cannot confirm if that is still the case though as I am too far away.
Charlotte, NC
I have a Uniden BCD325P2 I have some luck with until I realized I wasn’t picking up much because everything is simulcast or something. I bought it thought as a good middle of the road type scanner and don’t know much about tweaking it to do what I want to do. With the BaoFeng UV5R I was hoping to listen in on what I could with it ham radio wise etc ….just not sure about programming and frequencies and repeaters close to where I could at least hear something on it.
brian
DB Administrator
South Carolina
You are correct that the 352P2 struggles to decode simulcast P25 systems, such as the one used in the Charlotte metro area. There are things you can try in terms of antenna and placement but your results will usually be inconsistent and frustrating. The only scanner made that specifically supports P25 simulcast is the SDS100/200, which also happens to be the most expensive scanner on the market. That's just the reality of this niche hobby - there hasn't been much scanner innovation and development in quite a few years, and now there is very little competition to keep costs down.
You can monitor The VIPER P25 trunked radio system with your scanner as it doesn't use simulcast sites in Mecklenburg County, I believe. You'll hear some NCSHP traffic along with some other state agencies.
Check Repeaterbook for a more complete list of local amateur radio repeaters. Like radioreference, it's crowd-sourced information, so there will be some inaccuracies and omissions do the data. You can also try the websites of the local amateur radio clubs for repeater listings. It looks like there is a Charlotte Amateur Radio Club and a Mecklenburg Amateur Radio Society.
Chris0516
Pittsboro, North Carolina
All Mecklenberg County 911 is on Charlotte UASI. That is P25 Simulcast. You will need the SDS100(Handheld)/SDS200(Desktop/Mobile).
Charlotte, NC
Right now I’m just trying to get the UV5R programmed with some ham frequencies etc so I can at least hear something on it. I’ve caught a few things while scanning but not sure how to program it. Thank you!!!!
brian
DB Administrator
South Carolina
Use your Uniden scanner to search 145-147.5MHz and 442-445MHz. Let it run for a while and see what you hear. Evenings between 6-9pm is probably peak usage time for most repeaters. That should give you a list of active repeaters in your area that you can then program into the Baofeng. Keep in mind that you may hear digital noise on some frequencies, which is most likely a DMR amateur repeater, which the Baofeng cannot decode.
I'm not familiar with that line of radios, but I believe an application called Chirp will allow you to program using your PC, assuming you have a programming cable. That's probably easier than programming via the front panel. Actually, a google search reveals that there is dedicated programming software available for that model, so I'd use that.
Charlotte, NC
Awesome man. I think I can do that with my scanner. I’m super new to actually diving into things here but I have a little time and tired of putting it off. I sincerely appreciate the advice. Thank you!!!!!
Charlotte, NC
I was able to hear and find a frequency/repeater it seems to be out of SC…lots of SC talk. I programmed it into a little cheap Radioddity GC-5 radio I purchased for very cheap hahaha….it worked and was super proud of myself. I downloaded an app and paid $3.99 to start studying for my technician exam hopefully soon. Thank y’all all again….wish we were talking on the air but soon!!!
brian
DB Administrator
South Carolina
SC folks are the best, by the way. Much more chill than those stuffy folks in NC. :ROFLMAO:
OnYourSix
@ilovethesquad10 I would recommend before buying additional smaller, cheaper radios that you save the money you would have spent on those $100 radios for something that might provide you more coverage. A basic scanner like you have will listen to HAM without an issue, but you get what you pay for, and will need to spend more money to listen to the newest technology-based transmissions. you can always listen to Mecklenburg County North Carolina Live Audio Feeds on the web and OpenMHz while you determine what you want to invest in next. Plan on spending the $600.00 on one of the SDS scanners which should carry you into the next few years as technology improves.
