Broadcastify Aircraft ATC Feed Appliance Program
blantonl
Founder and CEO
Dallas, TX
In the next month, we are going to make a significant investment to increase our coverage of Live Aircraft ATC communications on Broadcastify. With this in mind, we are now accepting applications for volunteers willing to host a preconfigured feed appliance to monitor aircraft communications.
Our primary focus for this program starting off will be to cover tower communications at the largest airports. I envision that we will invest in and deploy about 50 of these preconfigured appliances to start.
If you are interested, you will need to meet the following requirements
- Have an antenna ready to go
- Have an ethernet connection to the internet
- Have the ability to monitor both air and ground communications for the airport
To get started, please fill out this form. We'll be in touch with those that meet our requirements for coverage. The feed appliance will be preconfigured and the only action that volunteers will need to take will be to connect an antenna, connect an ethernet connection, and power on the device.
Here is the form:
http://goo.gl/forms/gm17IZuiEt
Thanks!
blantonl
Founder and CEO
Dallas, TX
So far we've gotten about 25 applications, so keep them coming in!
Thanks everyone!
blantonl
Founder and CEO
Dallas, TX
Will your image allow more than 1 stream per RaspberryPi?
I plan on doing further testing for multiple streams over the next few days. Using rtl-airband you should be able to broadcast quite a few streams I believe.
DC31
Massachusetts
I did a bunch of testing today using rtl-airband on a Model B pi I had laying around. It looks quite promising. However, all my work is in the public safety band which is narrow band FM rather than AM. The AM band seems to be hard coded into rtl-airband. I believe that it is a simple parameter in the rtl command line (-M fm vs -M am) but I am not enough of a programmer to figure it out. Any chance that parameter could be made user configurable?
Jim
blantonl
Founder and CEO
Dallas, TX
We've received about 30 applications so far. I expect that I'll start purchasing the equipment next week and by next weekend we'll start building the first set of appliance and shipping out to the largest airpprt locations first.
frazpo
SW Mo
Raspberry Pi load
Nice work! Just loaded the packages on an original model Pi. Works fine, clean audio.
I still stream regular analog frequencies so this will be nice to have. Now I need another Pi for my ADS-B decoder.
mjbjr
Macon,Ga USA
I guess if i have to ask this then I may not be the right person. But what kind of antenna would we need?
krokus
Southeastern Michigan
Anything the picks up VHF aero band. There are some band specific antennas, or a multi-band antenna, such as a discone.
Sent via Tapatalk
KD0TAZ
Kansas
I'm not near any large airport, but I'm right between two regional airports (HYS and GBD) that do commercial puddlejumper service as well as private aircraft.. I'm 20 miles from HYS and 30 miles from GBD (although I'd have to see if I can hear GBD, there might be a line of sight issue) in the flight paths. I realize it would be low on the list but is that something you'd consider?
blantonl
Founder and CEO
Dallas, TX
If you can't get both the tower and aircraft, then unfortunately it is going to be very very low on the priority list.
blantonl
Founder and CEO
Dallas, TX
We've gotten all the equipment in today - now we'll be building the production image, doing some final testing, and beginning to reach out to those who filled out applications.
Stay tuned for more...
KD2DLL
Rotterdam, New York
Lindsay, I am currently going through testing to see what I can pick up from Albany International (ALB) right now, so far I can confirm Approach and Departure from east and west and Tower, but have not finished testing the rest. Should I put in the application in the meantime or wait until I can confirm what else I can pick up?
blantonl
Founder and CEO
Dallas, TX
We're shipping out our first test batch of 5 feed appliances this week. Airports covered this week include KIAD, KLAF, KBWI, KTEB, and KCLE
(Dulles, Purdue, BWI, Teterboro, and Cleveland)
These 5 airports give us a good test of single dongle and multiple dongle setup.
We've got about 18 ready to go after that provided things go smooth with the initial test run. We'll then do another batch of 25 after that.
Keep the appliance applications coming (see the original post) and we'll be selecting priority airports for coverage as we go along.
Thanks!
btrogdon
Forsyth County, North Carolina
Multi Feeds one Pi
Just a heads up my feeds (Six total) are streaming via the Raspberry Pi. Two feeds per Pi as my devices have only two USB ports. I have thought about trying the newer devices that have 4 USB ports.
-Brad
665_NJ
New Jersey
KTEB - ATC now LIVE
Hi Folks,
With Lindsay's assistance and guidance I'm up and running as one of the first of five Radio Reference's "test" nodes for ATC. Covering KTEB (Teterboro Airport, Bergen County, New Jersey)
Attached to the Raspberry PI are
1 RTL Stick - Monitoring KTEB Tower Primary and Alternate Frequencies (2 Freqs.)
1 RTL Stick - Monitoring the Aircraft Emergency Frequency (NY Area Guard) 121.5 MHz
1 3D USB Sound Card Dongle - Monitoring a RS Pro 2067 Scanner with NY Approach and Departure Frequencies for Teterboro
Using a Comet CX-333 Triband External antenna.
Please give these feeds a listen. Comments and suggestions welcome.
Otherwise enjoy the Labor Day weekend with your family and friends!
Max :cool:
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Lindsay any thought about doing both a ATC feed and a live ADSB feed of the local airtraffic to go with it?
