Does anyone have a workaround to send the "Broadcastify Calls Format" back into Brodcastify as a "Broadcastify Stream Format" so it can be monitored on the app as a normal county feed with the use of another system or webpage online short of actually feeding it back in a loop from a computer sound line looped back into the webpage? Maybe there is a legal problem with using the "Broadcastify Calls Format" to do that? It seems it could be done simply on the same servers since the feed is right on the server, to begin with. Maybe by allowing user playlists to be set to be available on the "Broadcastify Stream Format"
wiki.radioreference.com
