Good Day:
I put up a few of TrunkRecorder sites this past fall. Those are monitoring DTRS sites at high locations, that routinely cover traffic from several counties.
Just this morning, I was monitoring the actual log for the unit monitoring the Colorado DTRS site in SE Utah on Abajo Peak, I'm seeing & hearing traffic from both Dolores County SO (3670) and San Miguel County SO (8561) dispatch TG's but when ever TrunkRecorder tries to upload those files it's getting a 502 bad gateway error & broadcastify_uploader failed messages.
In looking through the Calls Platform, I don't see that the Dolores SO TG has ever been captured on the Calls Platform, yet the Abajo site is their primary coverage, and over the past 3 months that I've been running TrunkRecorder for that that site, I'm sure there have been many hundred if not thousands of transmissions on that TG.
Looking through the list of the captured talk groups for my TR site, it's only showing State Patrol and CDOT traffic, and no local TG's at all. Both of these TGs I've mentioned are listed as Law Dispatch in the RR Database so it shouldn't be a limitation on the tactical channels.
So is the Calls Platform doing some filtering of what Talkgroups it accepts based on the site that was signed up?
Chuck
Below is an example of one entry from TR
[2023-01-07 10:18:25.312473] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 Starting P25 Recorder Num [0] TDMA: false Slot: 0 QPSK: true
[2023-01-07 10:18:27.495781] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 Unit ID set via Control Channel, ext: 276334 current: -1 samples: 0
[2023-01-07 10:18:37.930907] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 Unit ID set via Control Channel, ext: 276306 current: -1 samples: 0
[2023-01-07 10:18:44.017938] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 Concluding Recorded Call_impl - Last Update: 4s Call_impl Elapsed: 19
[2023-01-07 10:18:44.018096] (info) [CDTRS] 6C - Stopping P25 Recorder Num [0] TG: 3670 Freq: 8.529750e+08 TDMA: false Slot: 0 Hz Error: -19 51
[2023-01-07 10:18:44.018283] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 - Transmission src: 276306 pos: 0 length: 1.08
[2023-01-07 10:18:44.018388] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 - Transmission src: 276334 pos: 1.08 length: 8.46
[2023-01-07 10:18:44.018548] (info) [CDTRS] 6C TG: 3670 Freq: 8.529750e+08 - Transmission src: 276306 pos: 9.54 length: 2.16
[2023-01-07 10:18:44.484820] (error) [CDTRS] TG: 3670 Freq: 8.529750e+08 Broadcastify Metadata Upload Error: <html>
<head><title>502 Bad Gateway</title></head>
<body>
<center><h1>502 Bad Gateway</h1></center>
</body>
</html>
[2023-01-07 10:18:44.485167] (error) Plugin Manager: call_end - broadcastify_uploader failed
Chuck
<body>
</body>
</html>
